dantheman0809 Honorable Oct 14, 2015 490 0 10,960 Oct 17, 2016 #1 I have been having a hard time hiding my cables in my thermaltake versa n21 case. I was wondering if there are any specific products which you guys would recommend and/or guides?
Solution Eldy Oct 17, 2016 Yeah like why_wolf said, zipties and also i enjoy using cable combs / clamps. Helps the ocd and keeping all the wires in order I know you can also get cable routing hardware if its not already provided with your case... or alternativley make your own
why_wolf Splendid Aug 28, 2015 3,639 184 27,090 Oct 17, 2016 #2 zip ties, so many zip ties. Upvote 1 Downvote
Eldy Reputable Jun 5, 2015 512 0 5,360 Oct 17, 2016 Solution #3 Yeah like why_wolf said, zipties and also i enjoy using cable combs / clamps. Helps the ocd and keeping all the wires in order I know you can also get cable routing hardware if its not already provided with your case... or alternativley make your own Upvote 0 Downvote Solution
frank_hnd Honorable May 6, 2016 1,038 0 11,960 Oct 17, 2016 #4 zip ties and velcro strips. Upvote 0 Downvote
