Best case fans
ethan_5
34
Recently i've been asking around for gpu water coolers and such because my components are getting to hot. I only just discovered i have 2 extra fans slots that fit 120mm and 140mm that i could use for cold air intake. Which case fans should i get to maximize my intake. I would maybe get three to replace a defualt case fan that blows the cpu air out. That is also 120mm or 140mm. I heard that 140mm is betrer because it blows slower with better results. Is this true?
and dont get me wrong i have corsair
ram,,psu,,keyboard
was just clarifying that they dont actually make them
so for example you could buy a psu with corsair name on it and it could be a bad,,or good,or excellent psu
as different ones are made by different manufacturers then corsair put on it
in theory 140mm is better
but thats subjective depending which 120mm you compare against which 140mm
and best fans? --ie make not size
noctua for one though they are still that awful brown/beige colour--unless its the industrial ones then can get black
phanteks in my opinion also make some good fans
bequiet
lot of people like corsair
just to clarify--a lot of companies dont actually make the fans--same as psus
so a fan/psu that says for example corsair on it usually isnt made by corsair just sold with their name on it
noctua is usually the best if you asked a lot of people their opinions
i already listed some decent ones
same thing they dont make them
companies like samsung,,intel,possibly hynix etc
they make the memory on ram and in ssds not corsair
other companies make the controllers on them etc
corsair probably dont manufacture any part of them if any
just put their name on them
Maybe , but i like corsair if i had the money i would buy corsair
then guessing corsair fans are too expensive where you are
that would rule out noctua as well then
yes that brand is expensive too ... but i have a thing for corsair
ram,,psu,,keyboard
