E epiques Mar 27, 2020 2 0 10 Mar 27, 2020 #1 Hello there, I just graduated from architecture department so I interest only with rendering and drawing. I do not play any game. Could you recommend me a motherboard as price/performance ? Regards.
Solution richiestang_78 Mar 27, 2020 The only "performance" metric for motherboards would be overclock potential. With a 2700X you can basically get an B450 motherboard and be fine. Here's a decent mobo which will be fine for stock and all but heavy overclocks https://pcpartpicker.com/product/hpRzK8/gigabyte-b450m-ds3h-micro-atx-am4-motherboard-b450m-ds3h Of course you can spend more if a mobo has a feature you want or you need more PCIe slots which you will need to get a full size ATX mobo. In that case MSI Thomahawk or Gaming are good. AsRock Pro4 is also a decent option. https://pcpartpicker.com/product/hpRzK8/gigabyte-b450m-ds3h-micro-atx-am4-motherboard-b450m-ds3h
richiestang_78 Glorious Mar 3, 2015 5,965 687 46,890 Mar 27, 2020 Solution #2 The only "performance" metric for motherboards would be overclock potential. With a 2700X you can basically get an B450 motherboard and be fine. Here's a decent mobo which will be fine for stock and all but heavy overclocks https://pcpartpicker.com/product/hpRzK8/gigabyte-b450m-ds3h-micro-atx-am4-motherboard-b450m-ds3h Of course you can spend more if a mobo has a feature you want or you need more PCIe slots which you will need to get a full size ATX mobo. In that case MSI Thomahawk or Gaming are good. AsRock Pro4 is also a decent option. https://pcpartpicker.com/product/hpRzK8/gigabyte-b450m-ds3h-micro-atx-am4-motherboard-b450m-ds3h Reactions: epiques Upvote 0 Downvote Solution
Wolfshadw Titan Moderator Aug 3, 2006 28,393 1,595 133,290 Mar 27, 2020 #3 PC Part Picker - Ryzen 7 2700X Compatible, 5-Star Rated Motherboards, sorted by Price from low to high. Look for high review counts and lower costs. -Wolf sends Reactions: epiques Upvote 0 Downvote
