Joe he said price isn't a problem so....
CPU - 4960X
MBO - rampage black edition
RAM - CAS9/2133/16GB
GFX - x2 Titan SLI
SSD - 850 series 256 GB/1 TB 10000RPM or 2 TB 7200 RPM
PSU - 1000W platinum rated etc etc
cooling well swiftech h220 but anything 150-200$ upwards will do ya.
CASE - entirely up to what you like. its all visual. NZXT
Thats if you can splurge. Corsair vengeance is good for splashing out, but don discount the other brands. corsair also do good PSU from what I have read. that should get around $10k for the build, but you said price isnt a problem. However if thats a little splashy, browse my build. I got 4000 from a tax back and that's what I'm working with. the ti and titan/titanZ just are not worth the price, and to get the performance well you have to OC then you gotta tweak the cooling add a custom GPU loop etc etc etc. anyways browse my build and lemme know what ya think.
http://www.tomshardware.com/forum/id-2268197/blueprint-1st-gaming-rig-advice.html
Also the reason I'm not advising on parts is because there are a ton of brands and my build is chosen from what I think is best, based on reviews. you should do the same and youll get a sensible build, not a money machine just thrown together.
