[SOLVED] Best cooler to fit AERO 800 windowed gaming case
Feb 22, 2019
Hi, I'm upgrading from an i5 8600K to an i7 9700K and want to run at 5Ghz. What is the best cooler I can jam in this case (Aerocool AERO 800 Windowed gaming case)
Cheers, Ols.
Assuming sticking with aircoolers?
Height limit for CPU coolers155mm
https://www.aerocool.com.tw/au/chssis/pgs-a/aero-800
Noctua's NH-U9B is a "standard" air cooler, be Quiet's TF is a downdraft cooler... both fit comfortably and should be capable of a 5GHz OC. Not going to be the best in terms of temps or noise, necessarily, but that 155mm clearance does limit you somewhat.
https://pcpartpicker.com/products/compare/Y4fp99,Y27CmG/
A Cryorig H7 fits too, although not 100% convinced it could do a stable 5GHz all-core.
https://pcpartpicker.com/product/bHcMnQ/cryorig-h7-quad-lumi-490-cfm-cpu-cooler-h7-quad-lumi
You do have the option of liquid coolers in that case too...
You do have the option of liquid coolers in that case too. Max of:
Water Cooling SystemFront : 120 / 140 / 240 / 280mm Radiator Installation.(MAX. 40mm thickness)
Top : 120 / 240 mm Radiator Installation.(MAX. 32mm thickness)
Rear : 120mm Radiator Installation.
Don't consider a 120mm solution though, as the air coolers above will rival them, if not better them outright.
240mm, minimum IMO.
Reactions: ols500
