best cooling for corsair carbide series air 540
R0nie
96
i have corsair carbide series air 540 case and have i7 4790k cpu which i will oc in future.............which liquid cooler among these 4 will be best for me?? corsair h100i or h110 or nzxt krakenx61 or 60 and how should i combine them with the fans that comes with the case or should i buy other case fans to get better effects.....and it will be great if anyone can explain how this guy in the video combined the fan with the coolers [ http://www.youtube.com/watch?v=cNEi8SvMYwM ]
Depends on your fan configuration but in general:
Fan in front: intake
Fan in back: exhaust
Radiator fan in top: exhaust
Fan bottom: intake
For the radiator fans, all of them should be in the same direction(eg exhaust).
I would go for the NZXT Kraken X61, it performs great. The fans that comes with it also perform well and are pretty quiet.
Here's a review: http://www.hardocp.com/article/2014/07/10/nzxt_kraken_x61_aio_liquid_cpu_cooler_review
The cooling unit comes with two fans, you can use those and it will perform just fine.
You can always add some extra fans, those you can connect to the motherboard and can be controlled via software.
The case fans can be connected on the motherboard as well.
Fan bottom: intake
