J juvenile Jul 31, 2018 8 0 10 Jul 31, 2018 #1 My case is Cooler Master Storm Scout 2, and i am unsure if the Noctua NH-D15 will fit in the case. If anyone got some recommendations for cooling would also be appreciated
Solution N N nobspls Jul 31, 2018 Define "best"? Did you mean only air cooling? A standard ATX case like that can easily fit many water cooling options. A 240mm water cooling solution like this would probably be really hard to beat: https://www.youtube.com/watch?v=goTgt7iOCpk
T TJ Hooker Titan Ambassador Apr 15, 2014 11,474 1,623 72,390 Jul 31, 2018 #2 Max CPU cooler height for that case is 162 mm. http://www.coolermaster.com/case/mid-tower/scout-2/ The D15 is 165 mm. But the D15S is only 160 mm, so that would work. Upvote 1 Downvote
N nobspls Reputable Mar 14, 2018 902 12 5,415 Jul 31, 2018 Solution #3 Define "best"? Did you mean only air cooling? A standard ATX case like that can easily fit many water cooling options. A 240mm water cooling solution like this would probably be really hard to beat: https://www.youtube.com/watch?v=goTgt7iOCpk Upvote 0 Downvote Solution
J juvenile Jul 31, 2018 8 0 10 Jul 31, 2018 #4 Alright thank you for the answers think ill go with the water cooling solution looks good. Upvote 0 Downvote
