Best CPU and Motherboard combo for under 300?
Vertex_Dreamz
14
My current PC specs are :
- AMD Athlon X4 860K 3.7GHz Quad-Core Processor
- Gigabyte GA-F2A88XM-D3H Micro ATX FM2+ Motherboard
- Kingston HyperX Beast 16GB (2 x 8GB) DDR3-1866 Memory
- Sapphire Radeon R9 270X 4GB Dual-X Video Card
- Corsair CX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply
- Cooler Master Hyper T4 70.0 CFM Rifle Bearing CPU Cooler
I am wondering what would be the best CPU and Motherboard combo for me to upgrade. I am only looking to spend up to $300. I just want to get an upgrade that will last for a while. Also I would like to have a full sized ATX motherboard so I can fit my CPU cooler on there since my ram is too big and the cooler is pretty big too.
With 30-50 fps on medium settings you're quite low on expectations. They say the frame timings are better on AMD processors where a game truly supports up to 8 cores/threads. That is the only benefit you can have with AMD CPU's.
Other than that you'll see better/more results frames wise with i5-4690 + H97 Fatal1ty depending on your GPU, which is still the route I'd suggest.
R9 270X can be improved with a much better GPU ofcourse.
I couldn't find an i5-4690k + good motherboard for 300 dollars so this my next suggestion for 300 USD:
CPU: Intel Core i5-4690 3.5GHz Quad-Core Processor ($206.93 @ Amazon)
Motherboard: ASRock Fatal1ty H97 Killer ATX LGA1150 Motherboard ($95.99 @ SuperBiiz)
Total: $302.92
Generated by PCPartPicker 2015-12-21 19:20 EST-0500
Edit: updated
Important info: If you buy the i5-4690k you can OC the H97 Fatal1ty Killer.
If you don't mind dropping the cash on extra RAM, this is a good setup, but you won't be able to overclock.
That's not the best value though, is it?. Paying too much extra over the FX-8320 for the 8350 whilst It's the same CPU but just overclocked. Also 108 dollars for a 970 Chipset motherboard is not very good.
With best possible mobo + Better CPU Cooler:
CPU: AMD FX-8320 3.5GHz 8-Core Processor ($134.99 @ SuperBiiz)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler ($27.99 @ Newegg)
Motherboard: ASRock 990FX Extreme6 ATX AM3+ Motherboard ($133.98 @ Newegg)
Total: $296.96
Generated by PCPartPicker 2015-12-21 20:12 EST-0500
He mentioned that he already had a cpu cooler, but yeah, that's a good point, you probably should go with the 8320 and just overclock it.
Well, I have a gtx 980 Ti, and a 144Hz monitor with GSync, and I easily maintain over 100FPS on ultra settings on most games at 2k. So as far as bottlenecking goes, you shouldn't run into any issues with a 270X
Okay. So what you are saying is that I will see better performance with the i5 overall than the AMD? And how long do you think this upgrade will last and still have good frames?
