H Hakz01 Commendable Mar 13, 2016 17 0 1,510 Mar 15, 2016 #1 Hi folks Looking to get the best cpu cooler to match everything else and to fit Colours I'm aiming for are black and red (red lights are a bonus) Build is Nzxt phantom full tower I7 4770k Maximus hero mobo Strix 980ti Ripsaw 8gb ram
Solution W W weberdarren97 Mar 15, 2016 I would recommend the Cooler Master Hyper 212 EVO as it's rated for 180watts, which will handle that CPU even with an overclock.
W weberdarren97 Glorious Aug 10, 2015 8,137 6 45,615 Mar 15, 2016 Solution #2 I would recommend the Cooler Master Hyper 212 EVO as it's rated for 180watts, which will handle that CPU even with an overclock. Upvote 0 Downvote Solution
W weberdarren97 Glorious Aug 10, 2015 8,137 6 45,615 Mar 15, 2016 #3 http://us.coolermaster.com/product/Detail/cooling/hyper-series/hyper-212-evo.html product page http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099&cm_re=hyper_212_evo-_-35-103-099-_-Product buy on Newegg http://www.amazon.com/Cooler-Master-Hyper-212-RR-212E-20PK-R2/dp/B005O65JXI/ref=sr_1_1?ie=UTF8&qid=1458091247&sr=8-1&keywords=hyper+212+evo buy on Amazon Upvote 0 Downvote
