best cpu cooling ? air vs water?
PachiMc
Commendable
Jan 14, 2017
228
hi , i have this case, coguar mx300 and i think i dont have space for a radiator at least a big one, my cpu is the i7 7700k and i overheating all the time, u think i should go with some corsair with a small radiator or with air flow ?
http://www.overclockersclub.com/reviews/cougar_mx300_review/
suggests it's unlikely you'll fit a 240mm radiator up top cause of vram clearance. Might try the front but I think those drive cages aren't removable so that's a bust as well. Not sure if rads smaller than 240 will keep up with 7700k better than something like NH-D15 would.
If you go with air cooling, make sure you get both 120 in front filled with fans. I'm assuming your back 120 fan is already in there and you can stick one more 120 in top back spot. If you're still heating up, you can add side fans but keep in mind these have to be speed controlled to lower speeds else they'll just mess up the airflow in the case and not help the temperature situation...
bring blue light ? i prefer with not i will look into a model without it xd
No no, the one with the red light I don't know anything about.
The blue one is the one with the review, that I know has decent temps. As for the color, it's just a fan. You can replace the fan with a non-rgb I think but be careful that it's the same model of the fan. Fans make a big difference in performance.
TY i will buy that blue of 800 😀
Jack, you feel this way "There is no instance where a CLC type water cooler beats a comparable priced air cooler. ". Cause i was thinking water cooler is always superior to an air cooler. But you say not so.
