G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt,alt.comp.hardware.homebuilt (More info?)
I am thinking of getting a Thermalright SP-94 heatsink. It does not
come with a CPU fan so I will need to get one. I have seen that many
people use Vantec Tornado Fan with this HS for maximum cooling but
56dBA of noise is too much for me!
I did some research and came up with the following choices:
Thermaltake Smart Case Fan 2 (80mm & 92mm)
Enermax UC-9FAB (92mm)
Panaflo FBA09A12H (92mm)
The Smart Case Fan 2 seems intriguing because it has variable RPM
adjustment and also a temperature control mode that switches to 4800
RPM when temperature measures above 55C so I am leaning towards this
fan. However, upon closer look, this mode may or may not be too useful
because in temperature mode, it switches between 1300 RPM and 4800 RPM
(I would rather it switch between, say, 3000 RPM and 4800 RPM, maybe
the variable RPM and temperature mode can be combined???)
Anyone with anyone experience with these or any other fans? Also what
is better 80mm or 92mm? On this point, there seems to be disagreement
as some say 80mm is better and other say 92mm is better and still
others say it is fan dependent.
I am looking for the most noise efficient cooling possible but with
enough cooling for moderate overclocking of P4 3.2C. On this score,
Panaflo seems intruiging because it has spec of 57CFM/35dBA, which
seems very efficient and sufficient.
Thanks for any feedback!
(Reply here please)
(Reply here please)
