Best cpu for 3d aniamtion rendering
lordraz2012
Commendable
Apr 4, 2016
Hi i am planning to buy a new pc this week, i need to know whether a pc with single cpu (with 4-6 cores ) is best for rendering or a pc with a multi cpu motherboard( 2 - 4 cpu motherboards) is much more suitable for rendering. I have 32gb of ram and a nvidia gtx960 card. Can i buy a 2 cpu/4cpu motherboard and put 2 / 4 i7 processors in them which makes the system powerful enough for rendering. As the rendering is to be done with maya and 3dsmax and i know that graphics dont do much when it comes to rendering, for gaming they are the best. My query is about 3d animation rendering. i have a 4 core i7 processor at present wth 32gb of ram and gtx card , but rendering is still slow . please give me a suggestion on this factor.BUdget can be around 2000$ .please give me a advice on this concept Thank you
Only specially-designed Intel Xeon processors can be used in multi-processor configurations. Those are usually designated as "xS" in the Scalability columns on Intel's website. Here's an example of a processor that is qualified to be used in dual-processor configurations.
http://ark.intel.com/products/91317/Intel-Xeon-Processor-E5-2699-v4-55M-Cache-2_20-GHz
You should know that rendering usually is a processor-intensive job. Some software suites can offload to GPUsto improve things.
I have not build a workstation bigger than the i7-5820K (6-way processor), and suggest you look at some of the samples on high-end workstation sites such as Lenovo, or Puget Systems for ideas.
Well, I went from a core 2 quad rendering pc to building an x99 6 core with 16gb ram intel 5820k and its really fast for me and thats just on stock settings. Its a bit faster still when overclocked but as I don't want to shorten the life span of anything I'm keeping at stock. What took a graphic intensive 12+ hours to render, now renders in 3-4 hours. For me that is a massive leep. Also the x99 gives me the option of going to a 5960k 8 core when prices drop later down the line. I would favour X99 for speed and cores which is whats needed for rendering. Down to budget and preference at the end of the day.
2x CPUS are really expensive. Normally you'd spend at least $1000 on the CPU, Cpu Coolers and motherboard alone.
PCPartPicker part list: http://pcpartpicker.com/p/FWbP23
Price breakdown by merchant: http://pcpartpicker.com/p/FWbP23/by_merchant/
CPU: Intel Xeon E5-2603 V3 1.6GHz 6-Core Processor ($209.99 @ SuperBiiz)
CPU Cooler: Cooler Master Seidon 120V 86.2 CFM Liquid CPU Cooler ($49.99 @ B&H)
Motherboard: Asus Z10PE-D16 SSI EEB Dual-CPU LGA2011-3 Narrow Motherboard ($389.99 @ SuperBiiz)
Total: $909.95
Generated by PCPartPicker 2016-04-12 13:33 EDT-0400
