Question Best CPU for RTX 3060
sleepcowboy
35
Hello there. What's the best CPU from AMD for the RTX 3060 under $200? I currently have a Ryzen 5 1600, but it's too weak for the 3060 and because of that it's not performing to its full potential. What can you guys recommend for me?
I personally have a ryzen 7 5800x paired with my 3060, and every single game I've played has run fine. Make sure if you're upgrading your cpu, that you also upgrade your cpu cooler if you're upgrading more than a few generations.
Reactions: Roland Of Gilead
So you want to look for anything that says all of the following:
TDP of 120w+
It has to be below 155 mm, but try to keep it under 150 mm
AM4 compatible
And then any other specifications, that's up to you. Some cpu fans are louder and spin faster, some are quieter and spin slower. Just depends on what your preferences are. Good luck 🫡
TDP of 120w+
AM4 compatible
OK I understood. I chose Deepcool AK620. What do you say?
