Build Advice Best CPU, Motherboard, RAM and CPU Cooler Combination for RTX 3060 12GB GPU ?
Apr 14, 2024
9
5
15
Please help me guys, i have Colorful iGame Ultra W-OC RTX 3060 12GB GPU and a 650w 80+ Gold PSU.
What CPU, Motherboard, RAM and CPU Cooler Combination should i get?
I have around $500-550 budget (around 8.000.000 - 8.500.000 in Indonesian Rupiah)
Should i go for a Ryzen 7000 with DDR5 or an Intel 12/13/14 gen with DDR4/DDR5 ?
Please send me suggestion, sorry for my bad english, thx
i just sold my old system with:
ASRock B365M PG 4
Intel Core i5-9600K
2 x 8GB Team Elite+ 3200mhz
Enermax T-40 FIT Dual Fan
650 watt 80+ Gold PSU
650W is the advertised wattage for the unit while Gold is the 80+ efficiency rating, what is the make and model of the unit and it's age(if you're recycling the unit)?
The community here isn't located in Indonesia but you should include links to the retailers you have access to so we can understand what we can look through. Make and model of the case helps too.
my PSU is Thermaltake Toughpower Grand RGB 650W Gold (RGB Sync Edition) and i bought it brand new in 2021
https://www.thermaltake.com/thermaltake-toughpower-grand-rgb-650w-gold-rgb-sync-edition.html
our retailer in Indonesia are
https://www.tokopedia.com/mpcsamarinda
https://www.tokopedia.com/enterkomputer
Please help me guys, i have RTX 3060 12GB (Colorful iGame Ultra W-OC) and 650 watt 80+ Gold PSU
i have around 500-550 $ budget (around 8.000.000 - 8.500.000 in Indonesian Rupiah)
Should i go for ryzen 7000 with ddr5 or intel 12/13/14 gen with ddr4/ddr5?
please send me suggestion, sorry for my bad english, thx
Intel Core i5 9600K
ASRock B365M PG 4
2x8GB Team Elite+ 3200mhz
CPU
https://www.tokopedia.com/search?q=amd+ryzen+5+7500f
AMD Ryzen 5 7500F
Motherboard
https://www.tokopedia.com/search?st...00.00&srp_page_id=&srp_page_title=&navsource=
https://www.msi.com/Motherboard/PRO-B650-S-WIFI
RAM
DDR5-6000 32GB (2x16GB) CL30
bro, that motherboard choice isn't available in indonesia
i was thinking this set up but i need second opinion
AMD Ryzen 5 7600X
ASRock B650M Pro RS Wifi
Kingston Fury Beast DDR5 5200mhz 2x16GB - KF552C36BBEK2-32 (AMD EXPO) (Non-RGB)
DeepCool AK620 Zero Dark
AMD Ryzen 5 7600X
Your RAM will be a bottleneck.
7600 > 7600X
The 7600 cost less and runs cooler.
7600 > 7600X
nice, this kind of information is what i need
so RAM need to be at 6000mhz, right?
Reactions: Why_Me
6000mhz CL30 or CL32. You can also save money going with a A620 board.
okay so on team Red this config
Ryzen 5 7600
A620
2x16 6000mhz CL30 or CL32
any suggestion with Intel or just go with AMD?
my Intel opinion build is this, give me suggestion please
Intel Core i5 14400
ASRock B760M Pro RS Wifi
Kingston Fury Beast DDR5 5200mhz 2x16GB - KF552C40BBK2-32 (Intel XMP) (Non-RGB)
That works...look at the Asus Tuf A620 wifi. If this is for gaming purposes the 7500F will also work fine while saving you money. For a Intel build look at the 12400F or 12600KF + B660 or B760 board + 2x16GB DDR4 3200.
so on Intel just skip gen 13/14 and go for gen 12 with ddr4 ram?
Reactions: Why_Me
For gaming purposes yes.
thanks buddy, well in Indonesia especially in Kalimantan (Borneo) we could only get Asus and ASRock brand for motherboard
MSI and Gigabyte are also available but they are hard to RMA in Kalimantan (Borneo)
ASRock and Asus Retailer and Customer Support is greater compare to other brand like MSI, Gigabyte and other
Reactions: Why_Me
Hey, one more thing
Is it worth to get 12400 or just go with 12400f?
U suggest me to get the F one cause it’s probably cheaper
But u know for some reason like gpu failure i consider getting the non-F one, well just in case
Please give me your opinion, really appreciate it
