Im currently using a Corsair Carbide 500R case with two Corsair AF140's installed in the top compartment.
Basically, one of the screws has a loud vibration even after I tightened the screw. I would like to buy some rubber vibration dampening fan mounts (ya know, rubber screws...) to eliminate the vibrating. Problem is I keep reading mixed reviews about every brand of screws I come across. The main issue seems to be that the screws do not fit the fan. I can't find much info about which screws to use with the Corsair AF 140.
Any recommendations? Thank you!
