Guigoos Reputable Nov 19, 2014 89 0 4,660 Nov 28, 2014 #1 I plan on utilizing all 6 fan slots in this case. No liquid cooling, I have a push/pull CPU cooler, and a large graphics card. Suggestions on best placement and orientation?
Solution USAFRet Nov 28, 2014 Basically, you want this: But why so many? And why push/pull on the CPU? You gain little if any benefit. http://www.overclock.net/t/1199135/hyper-212-testing-push-vs-pull-vs-push-pull-also-horizontal-vs-vertical-positioning
Lucias OKeefe Honorable Jun 18, 2013 354 0 10,960 Nov 28, 2014 #2 Bottom and right should be intake, with 140mm fans at the front. Top and left should be exhaust. This may be overkill, however. What on earth do you intend to run that you believe you could need six fans to move it's excess heat? Upvote 0 Downvote
ModernWarfare Splendid BANNED Jan 26, 2014 3,111 0 23,560 Nov 28, 2014 #3 front fans blow the air in the case rear fans blow out air out of the case bottom fan blows in air top fans blow air out. Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 177,100 20,657 184,590 Nov 28, 2014 Solution #4 Basically, you want this: But why so many? And why push/pull on the CPU? You gain little if any benefit. http://www.overclock.net/t/1199135/hyper-212-testing-push-vs-pull-vs-push-pull-also-horizontal-vs-vertical-positioning Upvote 0 Downvote Solution
