Best Fan/Rad Orientation for Kraken G10 in case
gl3nnn
I plan to install 2 kraken G10s for my SLI configuration but my question is what will be the best orientation possible for my setup is, there is little room between the EVO 212 and fan slot 1. I don’t know if I could place the radiator there, preferably not.
I was thinking of mounting the radiators at fan slot 4 and fan slot 6 since they are the only two slots that are currently empty. I plan to have dual fans doing a push pull configuration for both radiators
What I am worried about is if fan slot 4 and 6 has a radiator installed, there is going to be an increase of hot air in my system which the EVO 212 is going to be receiving. The vrams on my GPU wont be fan cooled because the G10 doesn't accommodate vrams that are on the left, i will have heatsinks installed on the vrams though.
Only fan slot 1 is exhausting all of the internal air. Should I change the orientation of fan slot 2 and 3 to be exhausting air as well or is there a better way to re-orientate all the fans and place the radiators differently, I don’t mind changing the entire setup.
The second card normally is very cool compared to the top one. Would you consider putting only 1 G10 ( Top GPU ).
If not, i would start using all your fan slots.
How about putting one of the radiators at fan slot 1 as exhaust and the other radiator on fan slot 2.
On fan slot 3 exhaust fan slot 4,5 and 6 intakes.
Btw if you don't use the Hard Drive Cage you should remove it for more airflow.
