Best graphic card for need and build
maraci
7
Hey guys,
I'm looking to create a solid build that I will use for software development (multiple VM instances, multitasking) and want to use to play games at high settings for the next few years.
I'm still in need of choosing a video card. My thoughts were either a GTX760, a Radeon 7950 or a Radeon 7970. I would like 3 monitor capabilities out of the box, but can settle for only 2, or 3 with add-ons/adapter. (Not looking to game on 3 monitors, but that could be cool).
Budget is 1300-1400$. Here is what I got (minus the video card):
http://ca.pcpartpicker.com/user/maraci/saved/2oc1
Thoughts? There are so many different models for each of those chipsets, and I'm quite lost here. I'm looking to spend 250-400$ for this card.
Any input/recommendations is/are appreciated! Thanks!
I recommend this one over the Sapphire model mostly because it is cheaper and will perform exactly the same more or less. The Sapphire card is also a great card but because the Sapphire model has a slight overclock they are charging a lot more for it and you won't really see a noticeable performance increase. I'm pretty sure you could achieve the same overclock with the XFX through free overclocking software.
I recommend it over the GTX 760 because the HD 7970 is simply a better card albeit more expensive, but because your price range goes to $400 the HD 7970 would be the better choice.
I'd like to make an educated decision :) Why do you recommend this one in particular? Compared to the Sapphire model, or compared to the gtx 760?
