best Graphics card for an Asus Crosshair v formula z
ZANDERtheGREAT
Commendable
May 27, 2016
5
hello.I am putting together a pc and i need to know which would be the best grphics card for an Asus crosshair v formula z and which monitor would go best with it.Ive been saving for a while so money inst an issue as long as the graphics card is worth it.
No it doesn't.
First off $700 Intels? Such as the 5960x? LOL
Lets start with the 4790k
http://cpu.userbenchmark.com/Compare/Intel-Core-i7-4790K-vs-AMD-FX-8320/2384vs1983
Or maybe the 6700k
http://cpu.userbenchmark.com/Compare/Intel-Core-i7-6700K-vs-AMD-FX-8320/3502vs1983
PS neither CPU is anywhere near $700, but lets go there, 5960X:
http://cpu.userbenchmark.com/Compare/Intel-Core-i7-5960X-vs-AMD-FX-8320/2580vs1983
As you can see all 3 CPUS absolutely demolish the 8320, now I will agree yours runs 0.4 ghz faster than they did, and its a cold day in...
GTX 1070. Your CPU(btw what is it? 8350? 9550?) will bottleneck the hell out of a 1080 unless you're gaming at 4k.
You should also begin to consider a platform upgrade. If you can do that soon, then you could go for the 1080 in preparation for your next build.
if you are just putting it together, get yourself an i5/i7 setup
it makes no sense to build an new am3 setup at all nowadays, wasted money for mediocre performance
Oh, I didn't read that correctly.
OP, maxalge is 100% right. Do not invest in taht dead platform!
Meh. If you're comfortable overclocking just do that. If you have an 8 core just overclock it to 4.8Ghz, you already have the motherboard. No point in upgrading to Intel right now.
Not many games can bottleneck an overclocked 8 AMD core, unless it's an older game that doesn't utilize multi-threading (Starcraft, World of Warcraft, LoL). You shouldn't be gaming at 4k yet anyway. Buy a 24" or 27" 144 hz monitor. 4k can only be displayed @ 59Hz and will give you a headache and cause eye strain over time. Not to mention you'll be gaming at 50FPS or lower which is just pathetic.
Intel was ahead for awhile because game developers did not move over to 4+ cores and threads, now that their starting to go multi-threading the FX series is aging like a fine wine. AMD is also releasing Zen this year so you can look forward to that and replace your CPU and mobo if necessary.
I would recommend the 1070 for a GPU.
Its an amd fx 8350
Nope. All money sunk into that platform is money thrown away at this point.
That's your opinion. He already has the platform so it's not wasted money.
My 150$ 8320 @ 5Ghz benches as high as 700$ Intels. Stick that in your pipe and smoke it.
ANY online game will be bottlenecked
ANY game which only uses 1 - 2 cores ( the vast majority of games )
FX have not aged well at all, you need to overclock to even have half way decent performance, and DX12 is no help at all
an overclocked fx 8 core can barely keep up with a gtx 970
So you already own the MB and CPU? Then get the 1070 if you don't plan to upgrade the platform any time soon and the 1080 if you do intend to and you are also considering going above 1080p/60hz.
What platform should i go with.Thanks for your help
Why would you even say that? You're talking out of your ass and clearly a deluded Intel fanboy. Please stop while you're ahead.
This guy literally has no idea what he's talking about dude. I get 100+FPS @ 1080 144hz with high settings in new games. I have an 8320 and an R9 380. Lol.
because its the truth?
look at online game benchmarks, some games can gain you 100% fps with an intel setup
Intel, obviously. You lost me. DO you already own the CPU and MB or not?
No it doesn't.
Or maybe the 6700k
As you can see all 3 CPUS absolutely demolish the 8320, now I will agree yours runs 0.4 ghz faster than they did, and its a cold day in hell before that small amount of frequency would make up that difference.
If we want to go with cold numbers (mind you passmark isn't the best but it works for relative comparison)
https://www.cpubenchmark.net/overclocked_cpus.html
Find the 8320 in that list, its just below a 3 generation old i7-2600
You like what you have and it performs well enough for you (PS your claim of 100fps on the newest games, yeah maybe on minimum detail), thats fine. In fact the FX processors can still perform viably with all new games.
However if you are buying brand new equipment, buying a processor architecture that was designed back in 2012 and at this point is completely dead and due to be replaced later this year is a bad call. Buying into it is NOT advice that you should be giving. Nor should you be flaming others on this forum about giving honest answers, not based on hyperbole that you have made up.
