Best graphics card for gx270
prodvcam
every time i try toplay a game a simple one like a hidden object i get
ialmrnt5 is not working properly, please reboot, and it goes to low resolution, will a new graphic card solve this problem as intell no longer supurts the 82865g graphics built in ....
what tthe best card its pent 4, 2.8 with 3 gigs ram
Hi newcomer and welcome to the Tom's hardware forum.
The problems with the upgrade of the GPU are two:
1- You need a GPU that fit in a smaller case.
2- You could need change the PSU, if you need change it, probably this will cost more that a normal ATX PSU, because the PSU of the GX270 is THIS and is really difficult find a PSU with the same form but with more power.
Try to install the latest drivers for your video card:
Go to Intel's Download Center and pick the correct one from "Graphics" section.
http://downloadcenter.intel.com/default.aspx?iid=Corporate+Header_Supp_downloads&
Other solutions that may be relevant:
- Check your refresh rate value. 60 Hz is usually safe, but can cause eye strain with CRT displays.
- Try that fix:
http://software.intel.com/en-us/forums/showthread.php?t=61435
- http://software.intel.com/en-us/forums/showthread.php?t=51557
