Best Graphics Card Setup And Storage configuration For 4K Build
Tony Sharp
86
Hi. I want to build a best 4k rig for gaming. And i am confused in gpu selection and storage selection. So please help me in detailed and quick.
1. One titan x or dual 980ti, which should i buy. Is there any maitenence or heating issue for one titan x or dual 980 ti. I am using cm storm trooper case. I will not overclock them, so does it neccessery to liquid cool these beasts.so which one setup is BEST,SAFE and RELIABLE for me,one titan x or dual 980 ti? AND WHICH BRAND FOR 980 TI. I love asus but there strix name is bad in meaning which is an owl which is understood bad in my culture. I dont prefer somthing named like that cause i am some kind of orthodox person. So is MSI is best over the asus quality durability safety and reliabilty?
2. I have my old 1tb samsung hdd and i am going to buy a new wd 1tb black. And also ssd, as ssd improves gaming load time.So should i get 2 ssd or 1 ssd for that, as one 256gb ssd for os and other 256gb for gaming in case os ssd fails,as ssd is not as reliable as hdd then my games will be safe on other ssd or should get one 512gb for both os and games or put os on one ssd only and put my games on hdd.How should i plan this thing for my data safety and reliability. I need performence and reliability yet safety too so i dont want to compromise in this things. PLEASE GIVE ME DETAILED SOLUTION TO COMPLETELY OVERCOME MY CONFUSION.
The dual 980ti is better than the Titan X in terms of gaming performance. Also if you're not overclocking then you don't need liquid cooling. I suggest the Galax 980ti HOF edition. Best 980ti config on the market right now.
SSDs are actually more reliable than HDDs according to statistics. But they're a relatively new technology so no one really knows. Just get 1 SSD. Why buy two? That's just a waste of money.
OK then that's fixed. So I am from India and galax and evga are not available here. So which are best graphics card brands excluding asus. And best ssd brand which is fastest and most reliable. Is pcie ssd is reliable?
The Gigabyte G1 Gaming is also good. So is the EVGA 970 FTW and the MSI 970 OC. Since you're in India also look for the PNY 970 and the inno3d 970 and the Palit 970.
The best SSD brand is Intel but they are rather pricey. Samsung also makes great SSDs. Yes they are reliable.
SLI doesn't really bode well with most games... It's much better to get one very strong card compared to an SLI setup. The Titan X isn't as strong as the 980TI in terms of gaming performance.
