Best Hard Drive?
jazperr
55
I'm after a 500GB HD - I want best performance and good warranty, looking for under £50, but I can go a little over.
AmazonUK links would be great,
Many thanks!
More or less all mainstream drives are pretty much the same. As long as you dont get one of the "green" models, differences are more or less too small to realize without a benchmarking tool.
Just get the biggest HDD your budget allows and you will be fine! :)
