Best IDE driver for 8RDA+
Archived from groups: alt.comp.periphs.mainboard.epox (More info?)
"DaveL" <dave1027@comcast.net> wrote in message
news:-q2dndETDqav5TfcRVn-3A@comcast.com...
> I have tried to install newly released drivers but I get
> http://mywebpages.comcast.net/dl1027/files/ide_error.jpg . Anybody having
> any luck with any driver other than the standard WinXP driver?
> DaveL
You have a system specific error. You must uninstall and reinstall the
Forceware Drivers for the nforce chipset.
Perhaps you have set a bios item improperly, or the HDD isn't (forgive me
for saying this...but you never know) IDE.
Faulty cable, faulty jumpers, bad windows install, any number of unusual
circumstances could have casued this.
Check BIOS for upgrade, Un/Re Install chipset drivers, do *not* let Windows
Upgrade download and install new device drivers!
Thanks for the help but I find what you are saying hard to believe. This
system runs flawlessly. What jumpers are you speaking of? This board has
no jumpers. The hard drive is a Maxtor 80 GB IDE. Pretty generic. I have
tried it with two different CD burners. Hard drive and CD burner are on
separate channels and both have 80 wire cables. There is nothing set
improperly in the bios. All things IDE related are set to AUTO. Block mode
is on. I tried it with prefetch on and off, no difference. I have the new
bios for this board. I did not install any drivers from the Windows Update
site. I did uninstall the old drivers before loading the new.
I don't think this new ide driver is compatible with this board. Until
someone speaks up and confirms that it works on the 8RDA+ I'll continue to
think this way. I think there is an outside chance that this driver is
smart enough to know that it will hose my system if it were to install so it
does not.
DaveL
"Friendly Guru" <someone@microsoft.com> wrote in message
news:1JCdnfIW0LTkCDbcRVn-tA@comcast.com...
having
> > DaveL
Windows
news:FIOdnUQMH_1DRDbcRVn-iA@comcast.com...
have
mode
new
Update
it
> does not.
> DaveL
This is not a global issue, your problem is system specific. Your
troubleshooting has been advanced, but did not uncover the problem. (btw,
your board has jumpers, make sure they are seated)
Please compare your .INF to this one (link) to check for errors.
http://files2.guru3d.com/nvidia/nvatabus.inf
