Hello. First posting.
Question is about getting the best hard drive performance using only a standard (read "old") motherboard having two IDE Ultra ATA100 motherboard connectors.
Background:
Will be using two (2) identical IDE Ultra ATA100, with 8mb ram, 7200 rpm. Drive 1 partitioned with small first-partition for OS. Drive 2 partitioned with small first partition only for page file.
QUESTION:
Is it better to use (A) a master/slave drive arrangement for these two drives, with one cable and only one of the motherboard IDE connectors, -or- (B) each drive set as master, one drive on one IDE motherboard connector, the other drive also set to master and singly connected to motherboard IDE connector. If (B), would use a separate IDE controller card (PCI) for CD drive used to load s/w. I might use the additional IDE controller card for a 3rd B-I-G hard drive for music and photo storage.
I know that separate drives for OS and pagefile is best, but never heard which connection philosophy is best. Cannot go to RAID card - too expensive in this case.
Thanks in advance -
Jack Woodward
Background:
QUESTION:
Thanks in advance -
Jack Woodward
