Best ips monitor
vampyiere6
832
What would be the best ips monitor for gaming mostly fps games but alot of other ones too.
And 3 of them i want they in eyefinity setup or would a 120hz/144hz monitors be better more smooth even when i think ips is the way to go now days because the colours.
and i want them to be 27" preferably even when i seen the 24" asus ips screen with 3d too.
so feel free to recommend me any screens that is good for 3 screen setup dosent have to be ips if they are really good and has to be 1080p screens atlast idk if 1440p would be better.
I know pretty much about screens but when i t comes to picking ips and 3 of them i am pretty lost since i never used a ips screen or 3 screens.
I will update my cpu later to amd 8350 or then go intel haswell i5 im not sure yet but here is my spec and i will maybe throw in another 7970 or a 7950 later too.
spec:
cpu: amd fx-4100
mobo: asus m5a99x evo
ram: kingston 16gb 1333 mhz 4x4 gb sticks
gpu: Gigabyte radeon HD 7970 oc 1000 mhz
storage: 120 gb ssd 60x2 ocz and 1tb normal hdd
cooler: antec kuhler 620
case: fractal design core 3000
psu: 730w thermaltake SP-730AH2NH
and i dident ask for a 120/144 hz ips screen i asked if a normal tn panel with 120/144hz would be better for gaming
yea but it is 3d i know there is no 120/144hz ips screen
The monitor you posted looks good but its quite pricy my budget would be about 1300$ for all 3 screens could go more if the screens are really good, and sorry if if i made the post unclear about what im asking
would 2560 x 1440 be much better then 1920x1080 do you yourself use that screen or that resulution would it be like noticable and so over normal 1080p?
Have a look at the full video 1440p on the left and 1080p on the right both 27" monitors https://www.youtube.com/watch?v=7vt0CJcUi4w
But yes 27" 1440p looks ALOT better then 27" 1080p let me give you the stats as well
at 27" 1920x1080 = 2073600 pixels and 81.59 pixels per inch
at 27" 2560x1440 = 3686400 pixels and 108.79 pixels per inch
