Best Large 2-Monitor Graphics Card - Clarity
incurablegeek
31
Basic Monitor Specs for I-Inc 28 inch monitors (2) - (IH282HPB) - http://www.i-inc-usa.com/product/ih282hpb.htm
Exact resolution: 1920 x 1200
Contrast ratio: X-Contrast 15,000:1 / 800:1 (Typical)
Displayable colors: 16.7 Million
Given the specs of the above monitor (will be running 2 of those 28 inchers and 1 POS Acer 22 incher), what ATI Graphics card would give me the Absolute Best Resolution and Clarity. What I do not wish to do is buy under-kill or over-kill, the meaning of "over-kill" being a card with more "horsepower" than my 28 inch monitors can handle.
Note: I use only Cooler Master HAF 932 cases and Noctua NH-D14 heatsink/fans. In short, I have plenty of room in my Cooler Master Case - IF I don't park my car in there, a sacrifice I am willing to make. 😉
No gaming and No EyeFinity required - yet.
Question: Since I want to achieve the Best Possible Resolution and Clarity from these monitors, would I be out of my mind to look at the Radeon HD 7950?
Footnote: My psychiatrist says I don't take rejection well, so please be as "kind" as possible in telling me I am FOS if you indeed believe so. Otherwise, I would hope for your honest suggestions. :sol:
Thanks!!!
HDMI:
Some computer monitors have HDMI inputs that are "HDMI-TV" inputs and only support the TV-VIDEO formats such as 1920x1080p NTSC. That's not a huge deal and mainly affects the ability to change resolutions but I thought you should be aware.
HDMI vs DVI:
If you have a DVI output on a graphics card and an HDMI input on a monitor then use a DVI->HDMI cable. you will not have any audio (except in some scenarios).
DVI outputs on video cards can output either:
a) normal monitor video, or
b) normal TV video
Confusing, I know.
The bottom line is that you will be able to hookup your two monitors though you may need to fiddle around with the Catalyst Control Panel to do it properly.
If a video card has 1xVGA, 1xDVI, and 1xHDMI you can...
I want to thank all of you, especially PhotonBoy and Sunius for sticking by me.
Both of you provided me with much of what I like and that is countable/measurable/confirmable information - things I can further check on to see what card would be the most suitable. I am a decision-tree thinker. :lol:
True, Sunius, most reviews are nonsense. You are indeed correct. That is why I read only for information that I can check up on later. For example, if a reviewer says specifically that ABC or XYZ is the problem, then I can check up on that and determine if it's true and why.
HDMI:
HDMI vs DVI:
b) normal TV video
If a video card has 1xVGA, 1xDVI, and 1xHDMI you can use two of the three, I'm just not certain if you can use any combination.
I would attempt to hookup the DVI and HDMI outputs first.
This response seemed to hit at the crux of the problem, i.e. the ports or hookups. While it's true I may have overbought in selecting the "GeForce GTX 550 Ti", I have also found that a little bit more money means better quality means fewer headaches down the line.
Thanks again all of you. Your every effort has been heartily appreciated. :bounce:
