[SOLVED] Best m/ATX motherboard and CPU for gaming/editing/streaming build
Ueki23
Commendable
May 21, 2020
15
Hello!! I am currently looking at upgrading my PC. I have a GTX 1080ti for gpu so I will keep that as it is. But currently have an intel 4600k cpu and a gigabyte ga z97 hd3 motherboard. Currently my Intel isn't supported by the latest adobe products for some reason so I'm wondering if i should get another intel or try out an AMD processor. My budget isn't a lot, but would like to keep it under $1000AUD if possible.
Any help would be appreciated!
This can be tweaked based on your needs.
PCPartPicker Part List
CPU: AMD Ryzen 5 3600X 3.8 GHz 6-Core Processor ($365.00 @ Shopping Express)
Motherboard: MSI B450-A PRO MAX ATX AM4 Motherboard ($178.50 @ Device Deal)
Memory: Team T-FORCE VULCAN Z 32 GB (2 x 16 GB) DDR4-3200 Memory ($214.50 @ Newegg Australia)
Storage: Crucial P1 500 GB M.2-2280 NVME Solid State Drive ($106.00 @ Skycomp Technology)
Power Supply: Antec Earthwatts Gold Pro 650 W 80+ Gold Certified Semi-modular ATX Power Supply ($149.00 @ Mwave Australia)
Total: $1013.00
Generated by PCPartPicker 2020-05-22...
Total: $1013.00
Generated by PCPartPicker 2020-05-22 22:50 AEST+1000
If only 16GB RAM is needed:
Memory: GeIL EVO POTENZA 16 GB (2 x 8 GB) DDR4-3200 Memory ($106.70 @ Newegg Australia)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive ($205.95 @ Amazon Australia)
Total: $1005.15
I included a PSU in each one since your PSU is probably old at this point. This also assumes that you will be reusing your case and other drives.
I might presume that your cpu is a i5-4690K processor.
I know of no reason why adobe would not support that processor.
Possibly because some functions need more than the 4 threads that you have.
In addition to a cpu upgrade you are also going to need a new motherboard and ddr4 ram.
For streaming and photoshop apps, you might consider more than the usual 2 x 8gb of ram.
Intel recently launched the 10th gen desktop processors.
The I5-10600K looks like a winner to me with 12 threads.
If you want to splurge, the i5-10700K with 16 threads is even stronger.
There are not many M-ATX Z490 motherboards at launch date.
Asus, asrock, and gigabyte have them, all for about $150 US.
I have little to pick among them.
If you will be looking at the i7-10700K, I might pick the asus rog strix Z490
on the basis of beefier voltage regulation.
https://www.newegg.com/asus-rog-strix-z490-g-gaming/p/N82E16813119294?&quicklink=true
Thank you so much guys!!
If I were looking for Micro-ATX as an alternative, what would be the best choices? (I also have a Silverstone Strider 700w PSU) My friend says to wait for a B550, is this a good idea?
