Cxrter Reputable Jun 1, 2016 27 0 4,530 Apr 24, 2020 #1 https://imgur.com/Vb1U407 View: https://i.imgur.com/Vb1U407.png theres the different options, whats the best one overall?
Solution rubix_1011 Apr 24, 2020 Fixed, 100% on anything that you have the ability to adjust and assuming it is setting to 100%. Performance just indicates performance, but doesn't necessarily mean '100% for 100% of the time', unless that gets stated somewhere.
rubix_1011 Contributing Writer Moderator Jan 12, 2007 16,702 676 60,190 Apr 24, 2020 Solution #2 Fixed, 100% on anything that you have the ability to adjust and assuming it is setting to 100%. Performance just indicates performance, but doesn't necessarily mean '100% for 100% of the time', unless that gets stated somewhere. Reactions: Cxrter Upvote 0 Downvote Solution
