Best Monitor For PS4
Since the ps4 can only output a maximum of 60Hz, no need for a fancy 120Hz monitor. You will just need something that will have 5ms or less response to ensure you get a smooth image during fast scenes, 1080p resolution, and HDMI. Here are a few monitors that are really popular among the pc gaming community which will have minimal lag.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236153
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236305
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236307
Hey! I bought the: http://www.newegg.com/Product/Product.aspx?Item=N82E16824236153 the
Asus VX238H
Was this a good choice? Thanks as well for answer! btw I also just ordered the PS4 with this too!
