A AlbanHampton Distinguished May 2, 2013 166 0 18,690 Mar 5, 2015 #1 Hi, I'm looking for an ATX motherboard to replace my Gigabyte H61M-DS2. I would like to spend no more than £80, would like USB 3.0 and 4 RAM slots in case I want to upgrade to 16gb, thanks in advance.
Solution Shneiky Mar 5, 2015 Can your case take ATX motherboards? Or you can only fit mATX? If you can fit ATX - then this is the best option I found, considering the scarcity and prices of LGA 1155 motherboards. http://www.alternate.co.uk/ASRock/Z75-Pro3/html/product/999536?tk=7&lk=4728
Shneiky Distinguished Aug 21, 2011 2,316 1 20,960 Mar 5, 2015 Solution #2 Can your case take ATX motherboards? Or you can only fit mATX? If you can fit ATX - then this is the best option I found, considering the scarcity and prices of LGA 1155 motherboards. http://www.alternate.co.uk/ASRock/Z75-Pro3/html/product/999536?tk=7&lk=4728 Upvote 0 Downvote Solution
