M marcggwp Commendable Jun 3, 2016 5 0 1,510 Dec 29, 2016 #1 I'm still pretty new at building but I was wondering what Motherboard I should upgrade to that can handle an AMD fx 4300 and Radeon Rx460.
Solution clutchc Dec 29, 2016 Basically ant board that has an AM3+ socket. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&IsNodeId=1&N=100007625%20600138080 The key is to find a board you like and then go to that board's website to check out the CPU support list. But the FX-4300 has been around so long that it would be an odd board that didn't support it.
clutchc Titan Ambassador Apr 22, 2009 43,152 411 131,790 Dec 29, 2016 Solution #2 Basically ant board that has an AM3+ socket. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&IsNodeId=1&N=100007625%20600138080 The key is to find a board you like and then go to that board's website to check out the CPU support list. But the FX-4300 has been around so long that it would be an odd board that didn't support it. Upvote 0 Downvote Solution
M marcggwp Commendable Jun 3, 2016 5 0 1,510 Dec 29, 2016 #3 clutchc : Basically ant board that has an AM3+ socket. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&IsNodeId=1&N=100007625%20600138080 The key is to find a board you like and then go to that board's website to check out the CPU support list. But the FX-4300 has been around so long that it would be an odd board that didn't support it. Thank you very much. Upvote 0 Downvote
