Best OBS Setting for 720p 60fps or 1080p 60fps
fakegaming933
I want to record my gameplay of Subnautica at 720p or 1080p
Right now I can record the gameplay but it look fuzzy.
System Specs
  • Ryzen 3 1200 @4ghz
    GIGABYTE GTX 1050 OC by 25%
    8gb Ram
    Windows 10 64bit
I don't see why you shouldn't be able to record at 1080p, if it's fuzzy you might just need to turn the bitrate up. However may I reccomend using shadowplay which is a technology built into your nvidia graphics card which will give you the best performance. You can find a tutorial on how to do so here: https://www.howtogeek.com/259573/how-to-record-your-pc-gameplay-with-nvidia-shadowplay/
So I just got to turn up the bitrate
