Chances are, unless there's someone selling this as a service (in which case the landscapers would probably just pay for it themselves), you're going to have to build this from scratch.
There are a ton of different routes you can go. Needless to say, you'll be learning HTML and at least one programming language. Resources abound for learning to program and build web applications, and I'm sure some other users will provide a host of useful links, but I'm not going to because I'd rather not bias your learning path in any particular direction.
It may be useful to look at how to break down your service into its component parts to see how they fit together and if you can provide only some portion of your whole initially, and if you aren't...
