Hey Guys!
For my first build, I'm using a Corsair H80i to cool my i7 4930k. It's been a few months and everything is great, temps are low, but the fans on it are just so loud! They have this constant whining. I'm using the CM Storm Stryker case which stock fans did not make nearly the amount of noise I expected, but at least its just the sound of moving air. The H80i's fans have an actual whine to them (if you happen to remember the sound of the original Xbox, imagine that). So my question. Is there a way to fix this without purchasing new fans? If not, what are the best fans to replace these with quiet being priority? I'm not overclocking.
Thanks a ton guys!
Thanks a ton guys!
