Question Best recommendation for software to scan a hard disk to detect and fix errors mostly for SSD as 2.5'', M2 and nvme
Manuel Jordan
286
9
4,685
Hello
According with your experience what is your best recommendation for software to scan a hard disk to detect and fix errors if is possible mostly for SSD as 2.5'', M2 and nvme.
And taking in consideration it should apply for any manufacturer, Samsung, WD, Crucial etc ...
Thanks in advance
Hello
Thanks in advance
The best recommendation is a good backup routine and warranty replacement.
Often, no matter what you do, the drive is gone gone gone.
I am agree with your two thoughts, but consider to apply the same question to only for scan purposes and know if exists something wrong or not.
Thank You
