Best replacement for my old set up under 7k INR
Meishaha
Hi . I collected a budget of 7k inr and I need to upgrade my old rig . It's current specs are
Intel Core 2 Quad @ 2.33Ghz
Nvidia GT 430 2GB
4Gb ddr2 RAM
Intel DG41RQI desktop board
What's the best thing I can change with a budget of under 7k INR . I know can't improve much . But just want to run bf4 at 40+fps on low . It's currently on 25 fps on low
The best options would be a HD 6570 DDR3 or 6670 GDDR5.
Also a new psu might be needed if the OP has a bad quality PSU.
What's the model no of the PSU?
if your rig has sata hard drive and cd rom and a standard atx case and power supply you can reuse them. you could use a newer h61 chipset intel mb and a ivery or sandy bridge cpu and a newer 650/650 ti or 7700 gpu. and ram. if the b/h 77 chipset mb are the same price go for the h77 mb.
I think the obvious choice is to upgrade the GPU, that board also supports a max of 8gb ram, so that is an option down the road as well. I understand the desire to buy it now, and have instantaneous gratification, but you may want to hold out and save up a few more bucks to get what you want, opposed to what you can afford now.
7000INR=113USD!
