Hi there i have been designing my dream PC for a while now and i have worked out most of the kinks except what fans two use the quick version of the build is that its a quad titan black, i7 4960x dual quad radiator system all inside a corsair obsidian 900d case.
I am looking for a good set of fans for the build, I don't have a specific preference for quite or performance, so i would most like good performing fans but that if need be i can turn down for silence but still have decent temps.
I currently am looking at the Corsair case fans cause they look good and seem to have good specs but i don't know which would best suit my preference. Or if a better set of fans would suit my needs that is also very helpful .
Air Flow - http://www.amazon.com/Corsair-AF120-Performance-Single-CO-9050003-WW/dp/B007RESGBC/ref=sr_1_1?s=electronics&ie=UTF8&qid=1400377360&sr=1-1&keywords=corsair+af120
High Performance - http://www.amazon.com/Corsair-SP120-High-Performance-CO-9050008-WW/dp/B007RESFYK/ref=sr_1_1?s=electronics&ie=UTF8&qid=1400377293&sr=1-1&keywords=corsair+fans
Static Pressure - http://www.amazon.com/Corsair-SP120-Quiet-Twin-CO-9050006-WW/dp/B007RESFR2/ref=sr_1_1?s=electronics&ie=UTF8&qid=1400377275&sr=1-1&keywords=corsair+silent+fans
