Hi, what is the best settings for nvidia mobility cards? Also I think my cpu not work turbo boost technology? How to check, or enable it? i5 - 2430m + gt525m. Thanks...
Overall gaming, work performance for gpu. Also I think my cpu runs only 2.4 Ghz, when it must run about 3,0 Ghz with turbo boost. How to check mhz rate and activate turbo boost if it's disabled? Also my pc goes very laggy, maybe there is problems with gpu drivers, should I use older recommended drivers, than the newest one???
You don't need to set any options for the video card, although you may want to set it to use the nVidia card all the time unless you are worried about battery life. For a 525m you would want to run most games on low, that is a video card from 4 years ago and a lower model when it was new.
The system should start the turbo boost when needed, the options to enable and disable it would be in the BIOS.
