F FINNIE8OY Reputable Jun 7, 2017 41 0 4,530 Jun 22, 2017 #1 on which settings do i have to play when i want 60-80 fps on gta 5? specs: GPU: NVIDIA GeForce GTX 950 2gb COU: AMD Athlon x4 860k Ram: 8gb Thanks if you answer!
Solution vrumor Jun 22, 2017 As low as you can go. You have a entry level CPU at best and an entry level GPU. Id say you meet minimum specs but not by a wide margin.
vrumor Judicious Jan 17, 2012 7,747 1 35,015 Jun 22, 2017 Solution #2 As low as you can go. You have a entry level CPU at best and an entry level GPU. Id say you meet minimum specs but not by a wide margin. Upvote 0 Downvote Solution
