Best Single Monitor Stand
EdwardBu
48
Hey,
Recently I have purchased a Samsung 32inch curved monitor for my desk (S32E590). However, with the base being curved to support the monitor, it is taking up a lot of space on my desk.
I am looking for a very sturdy and robust monitor arm which can swivel and can be clamped to the desk so that I am able to move it around while freeing up some desk space.
If anyone has any recommendations then that would be greatly appreciated.
Cheers in advance
Edward
Ergotron hands down. They're not the cheapest but they're the best I've run across. I use a dual set for dual 24in monitors and have never looked back. The help to my upper back and shoulders alone made it a worthwhile purchase.
http://www.ergotron.com/Products/DeskMounts/tabid/71/Default.aspx
Amazon here in the US sells their own branded knock offs that look like they may be either a really good copy of ergotron or ergotron is OEMing it for them. Not sure if you'd get the same from the Amazon in your country.
