Hello – can anyone suggest a single slot Graphics Card?
I have a 460 W PSU with a 12v rail with 30A. The problem is I don’t have room in my case for a double slot card which limits my options.
I’m running Windows 8.1 so I want something 8.1 compliant with UEFI BIOS. This will disqualify the single slot GTX 600 series and AMD 7750’s and 7770’s which I know would otherwise be my best options.
I think my best options for my requirements are the single slot R7 250’s.
Assuming the R7 250 is my best option, is it that much of an upgrade over my Haswell integrated HD 4600? I haven’t seen any direct comparison benchmarks. I’m assuming the performance would be at least double.
The only gaming I do (currently) is Skyrim. Oblivion, and CIV 5.
Thanks!
Thanks!
