Question Best site to buy used parts from?
Oct 12, 2019
14
Title says it all.
Looking to maybe buy some used RAM sticks from a trusted & safe website that sells used pc parts, or just any site that sells parts a lot cheaper then most sites and usually allows returns. Thanks!
Sent from my iPhone using Tapatalk
Mrgr74
Notable
Sep 2, 2019
548
105
840
73
Title says it all.
Depends on where you live. :) Do you have any electronic recycling places near you? They often have a small shop on the side that will sell the items that still have life in them. I live in the US here in the PNW and there are a ton of said recycling places. Of course you have to be careful, but Craigslist often has diamonds in the rough. Just gotta be savvy and watch for scammers. ALWAYS insist on seeing the item actually running. There is also eBay, Pricewatch.com is good to find cheap off-brand (and often name brand on sale) hardware.
Oct 12, 2019
14
Thank you, I’ll check to see if I have any of those nearby.
I’ve never considered searching on craigslist but I’ll take a look to see what I can find : )
lynx1021
731
82
5,040
26
You have to be careful on craigslist, if it sounds to good to be true it is probably a scam. I have had good luck on eBay and Amazon sells used stuff also. Newegg has some refurbished stuff also.
Reactions: Ysertila
