[SOLVED] Best speed ram speed
madoococa
Commendable
Oct 2, 2021
28
I need a ram for my pc.
the question is what to select high freq or Low Latency?
XPG D50G 16GB (2X8) 3600 CL18
1,850.00 EGP
or
XPG D50G 16GB (2X8) 3200 CL16
1,650.00 EGP
You wouldn't feel a difference.
The 3600 cl18 can be made into 3600 cl17 or even cl16 quite easily with tightening the timings, but the 3200 cl16 will be harder to make if possible into 3600 cl16.
The 3200cl16 should be like ever so slightly faster, but the 3600cl18 can be made into a few precent faster.
What platform are you looking to pair those proposed ram kits with? Ideally if you can get tight ram timings with high frequency at a good price, go for it, otherwise go for lower frequency with tight timings. C16 isn't tight timings, mind you. What other kits do you have access to?
