S Sagar_20 Distinguished BANNED Jun 29, 2016 881 93 19,540 Oct 30, 2017 #1 Which is the Most powerful TFX Power Supply that can be used for Dell and Hp Pre built SFF desktops?
Solution geofelt Oct 30, 2017 400w seems to be the limit.. But, the quality may be suspect. Consider using a Seasonic 350w TFX unit which will easily power a GTX1050ti.
geofelt Titan Oct 9, 2006 55,456 4,588 174,240 Oct 30, 2017 Solution #2 400w seems to be the limit.. But, the quality may be suspect. Consider using a Seasonic 350w TFX unit which will easily power a GTX1050ti. Upvote 0 Downvote Solution
