Best Thermal Paste for CPUs 2025: 90 Pastes Tested and Ranked
Page 4 - Seeking answers? Join the Tom's Hardware community: where nearly two million members share solutions and discuss the latest tech.
To Garret and Paul, guys you have the most comprehensive thermal paste comparison on the internet: we need Corsair XTM70 and Arctic MX-6 the current benchmarks of no liquid metal performance, for the list to rock again.
We tested 90 different thermal pastes to help you find the best one to help cool your CPU.
Best Thermal Paste for CPUs 2021: 90 Pastes Tested and Ranked : Read more
I've been using Nocta's paste pretty exclusively for the last decades, because it came with their coolers, which I've also used pretty much exclusively for about as long. The performance of both has typically been rather well, was long as the CPU's Wattage and the cooler variant were matched.
I like Mini-ITX as a form factor to build µ-servers, they are not much bigger than NUCs yet offer a lot more flexibility for building your own and recycling components.
I also like the 28-45 official TDP range for SoCs, because those µ-servers typically run 24x7 and energy/heat is an issue and because modern laptop SoCs can deliver quite a punch without going to the extremes of 250 Watt+ peak power draw.
But only the more enterprising Chinese manufacturers seem to deliver that combination of small and powerful, often after Intel starts discounting last generation chips.
Typical case in point are Erying boards, in my case a Mini-ITX G660 with a soldered i7-12700H, two DIMM slots and plenty of expandability via M.2 slots.
They come with a custom heat-spreader to cover the naked mobile die and make it height-compatible with a typical desktop cooler expecting a lidded chip. Since it's officially a 45 Watt TDP SoC and the chassis is the typical minimal Mini-ITX case I went with a Noctua NH-L9i-17xx fan, which is supposed to cover up to 65 Watts.
I've used that and its slighty bigger brother NH-L9x65 in a lot of builds for systems in the 35 or 65 Watts range respectively and found it rather capable of handling peaks in a very relaxed manner, using the relatively high mass of the cooler to store heat, which was then dissipated over time by the relatively low air-flow fan (it's small and thin after all).
The system was rather disappointing and somewhat puzzling, it never seemed to get hot, rarely reaching 70°C yet it signalled thermal limits nearly all the time, never going much beyoned 25 Watts at sustained loads, according to HWinfo.
I replaced the orignal paste between the naked SoC surface and the Eryin heat-spreader with Noctua's paste (also used between the heat-spreader and the Noctual cooler), but that didn't really do a lot.
Since there was such a lot of bad press about Intel using paste between their naked chips and the heat-spreader I thought it a good opportunity to test liquid metal instead of paste, even if the 4°C range cited here didn't exactly hint at a giant difference.
The other motive was that the SoC doesn't have any capacitors or contacts near the die, actually features a bit of a basin around the die carrier and the system is operated "sunny side up" (actually down), meaning there would be no risk of liquid metal seeping onto the motherboard creating shorts.
I've never seen such a night-and-day difference!
I'll freely admit that I typically only pasted on top of heat-spreaders, but I can't have done a completley incompetent job either, because the Noctua paste decreased the original temps at least a little bit.
But with the liquid metal, the SoC was unrecognisable! Where the fan would spin to its max 2600rpm at only 25 Watts before, it now stayed at a rather less noticable 2200rpm while the SoC kept going on its default PL1 limit of 95 Watts--on a cooler that is rated for 65 Watts! It just never slowed down and temperatures stayed around 75°C, too.
Now those temperatures had actually been indicated at slightly less before via HWinfo, not even reaching 70°C. But I am pretty sure now, that those were "false readings" in a way: the SoC would overhead so rapidly on paste, that it had to throttle brutally, resulting in the 25 Watt consumption but also rather "mobile" clocks.
Now with Conductonaut liquid metal the SoC could actually go to its full potential and never throttled.
I also applied it between custom heat-spreader and the Noctua cooler, which might have had less of a dramatic effect, but since there was plenty left over and the spill risk due to the upright position remained minimal, it seemed the best thing to do.
PL2 turned out the next challenge, because the Pico-PSU only supplies 120 Watt maximum and any Alderlake will take a huge draw from the power bottle, unless it's constrained. And there are some YouTube videos which show that the power delivery circuitry on the board is simply not matched to the 168 Watts the BIOS allows for PL2.
But constraining the power inputs to something that fits the SoC's official range and the board design (I settled for 65 Watts sustained) is a snap and now has the fan remain below 2000 rpm, completely unnoticeable underneath my table as a side benefit. Peak performance is hardly impacted and for sustained workstation loads I have workstations.
My major conclusion is that in any naked die scenario, the benefits of liquid cooling vs. paste are way bigger than between heat-spreader and cooler.
Pretty frustrating when best designations go to products with poor performance, went to buy some recomended product with a score of 3-4 on ease of use and conductivity and all the newegge reviews for it said none of them could spread it on their cpu's sounds pretty schetchy man
Any chance you guys could review this thermal paste from TCRS Circuit? He's well known from the Louis Rossmann circle and has been making his own paste in the US for a while now.
Would be interested to see some in-depth tests on it.
View: https://www.youtube.com/watch?v=P0k5PxQerlE
I'm curious about when Tom's Hardware will test the CoolerMaster Cryofuze (MGZ-NDSG-N07M-R2) and how it compares in practice with Cooler Master MasterGel Pro v2 and other thermal pastes.
CoolerMaster Cryofuze (MGZ-NDSG-N07M-R2) claims to have 14 W/m.K of Thermal Conductivity. For comparison, Cooler Master MasterGel Pro v2 (MGY-ZOSG-N15M-R3) has 9 W/m-k of Thermal Conductivity.
https://www.coolermaster.com/catalog/coolers/thermal-grease/cryofuze/
Note: Remember that CoolerMaster Cryofuze (MGZ-NDSG-N07M-R2) is a different product from CoolerMaster Cryofuze Violet (MGY-NOSG-N07M-R1).
I bought mine on Aliexpress since it's still pretty hard to find it in Brazil for prices that aren't indecently expensive https://s.click.aliexpress.com/e/_DEvXHEl
i said it in past
i'll say it again.
The "best" (aka #1) is the best performance price be damned (as ppl dont care about price when they choose the best)
#2 being best but relegated to #2 because it costs more is legit dumb.
Thats like saying a 4080 is better than a 4090 because its cheaper and does well enough.
Only reason price is ever a facotr is for budget. (as those are the price caring group)
i said it in past
i'll say it again.
The most expensive is not always the absolute "best performer".
Reactions: ReveurGAM
Why publish this again in 2023 and call it "Best Thermal Paste for CPUs 2023: 90 Pastes Tested and Ranked" if there's no actual retesting and updating for new thermal pastes?
Is there a way to clarify the rankings on this chart, the way it's setup with 13 "best" options is a little muddy.
What's the difference between "Best Budget Thermal Paste" and "Best Budget Paste" why are those separate categories?
How does "Best Price/Performance per gram have a performance rating on 1 (lowest) especially when the winner of "Best Budget Paste" has better performance and a lower per/gram price?
How can the "Best Budget Thermal Paste: Runner-Up" be more expensive per gram then the Best Premium Alternate and the Best Premium All-Around? Shouldn't all the premium pastes be better performing but more expensive than the budget pastes?
How can the Best Budget Performance paste have a performance score of 1 (lowest)?
So what does "Premium" mean then?
If it just means price, how come there's "budget" pastes that cost more per gram then premium pastes (GC-Extreme is a budget paste at $3.70/gram vs Artic MX-5 is a premium paste at $2.75/gram)
If premium means performance, how come the MasterGel Pro v2 isn't the best budget performer since it's both a better performer and less expensive than the SYY 157?
Plus all the other questions above.
If it just means price, how come there's "budget" pastes that cost more per gram then premium pastes (SYY 157 is a budget paste at $2.99/gram vs Artic MX-5 is a premium paste at $2.75/gram)
Dunno.
I did not write either the advertising copy, nor the results.
I think the main takeaway for this is seeing the very small temp delta between "best" and worst".
(apart from the outliers at each end)
At first glance it is surprising that the No.1 paste is PK-3, given that it is not the best performer among the non-conductive pastes according to your benchmark. I've been using PK-3 since it became available in my country, >13 years ago. It has great thermal conductivity, but it's by no means easy to apply (you spread, and you spread and you spread and on the final swish it all gets stuck on your spatula and you have to start again from the beginning). The most important thing about it though is that it doesn't age. Just a few weeks ago I dismounted a cooler 10 years after it was mounted and the paste looks exactly the same as on day 1...
my pc is connected to 65" screen 3840x2160
pc power is set to balanced.
Room temp 25C, look at these temps while browsing internet and playing uhd movie.
thermal paste i used is this one
funny thing is that this grease cost nothing and any graphite grease will work better than any of these super duper arctic silver $100 1g cpu paste.
forgot to mention no water cooling and such, standard atx case and there are only two fans inside case one pulling air out working at 450rpm and second cpu fan 300rpm.
kingston nv2 2tb these are rubbish nvme drives i bought two thinking will use them for storage dont recommend them without any heatsink their temps were 50C while idle. with my own custom garage made $10 heatsink plus $2 graphite grease even these nv2 drives when 100% load never go over 40C.
so beat that
Sounds like it's phase changing.
so beat that
That's electrically conductive, right? Looks good but I only see it in the UK not the USA. Do you know which brand I should try here?
