Best water cooler and tips on fitting it into a Bitfenix Prodigy?
HunterW
53
What's the best liquid cooling system that I could get for ~$150? I'm getting the i5-3570k and wanted to do some overclocking. Also, what would be some good tips on fitting it in the Bitfenix Prodigy case? I was wondering if anyone else that's done this ran into any setbacks or problems that I should know of. Also any information, suggestions, or tips would be great. Thanks!
Hey,
For $150 you could get a Corsair H100, if you are looking for a closed loop cooler. If you want a custom loop then $150 is a bit of a tight budget.
Hope this helps!
Dear Hunterw,
It appears that your case supports a 240mm radiator. Have you looked at our Eisberg 240L or Glacer 240L? Both of these coolers are under $150 on newegg.com
Please let me know if you have any questions
How much would I be looking at for a custom loop cooling system?
I'll look at those, thanks!
