Hi
What is the best / easiest way to control and synchronise all RGB in my PC I'm building?
Will I be able to control all RGB from one Place?
I have:
1) B650 steel legend motherboard (with 3 ARGB connectors)
- 3 ARGB connections
2) ARCTIC Liquid Freezer III 240 A-RGB - Water Cooling PC, All-in-One (2 fans and pump connected)
- will require 1 argb connector (on motherboard)
3) case NZXT H6 flow with prebuild 3x 120 argb fans (they are already daisy chained and connected to an adapter - will require 1 argb connector (on motherboard)
4) 2x 140 NZXT fans (comes with NZXT hub/ connector that plug into motherboard USB and sata for power)
5) TeamGroup Delta RGB 32GB (2X16GB) DDR5
will I be able to set / control each component (f.e. Each fan in daisy chain in case, pump separately to fan on AIO etc..)
Should I get NZXT hub for all fans?
I would like to have all setup synchronised to have something like 2 colour rainbow on slow loop if that make sense?
I noted windows dynamic lighting is a thing but not sure will it see all parts?
I have:
