Let me apologize ahead of time for my ignorance. Having isolated packet loss to between a computer and default gateway, and without the ability to test on another computer or troubleshoot physicals, what is the best way to determine what is causing the packet loss (computer/router/Ethernet cable)?
We can assume the packet loss is either the computer (hardware/software), Ethernet cable or router (hardware/software), correct?
Are there network tests that can be performed to further isolate (things other than assuming it's one or the other and either kicking computer into safe mode/antivirus scan/reinstall NIC drivers/powercycle router, etc.)
Would a lack of packet loss when pinging 127.0.0.1 combined with packet loss when pinging default gateway be indicative of an issue with Ethernet Cable/router? I don't feel that would be comprehensive. My goal is to determine the best way to isolate packet loss of this nature.
Edit:
I'm speaking generally (and I'm aware as a result you may not be able to provide any help). In an enterprise environment, when an end user calls in and indicates they're experiencing VPN stability issues. After disconnecting them from the VPN and isolating the packet loss to between the computer and router (without the ability of seeing interface statistics and with each user's setup being different), is there a reliable way to isolate the packet loss. What is an efficient method of "proving" the cause of the packet loss so that either A. we can convey to the user they should contact their ISP or B. escalation for troubleshooting/computer troubleshooting can be performed?
Thanks for any assistance.
Edit:
