G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
Hello all,
I'm making the jump from a 120gb IDE drive to TWO 300gb SATA drives
(Maxtor 6B300S0 drives). I'm doing away with the IDE drives all
together, and going purely SATA.
My question is.. what is the suggested partitioning scheme when using
such a large drive as the system drive? With 80gb and 120gb drives
I've used in the past, I've simply used one big NTFS partition. But
with these 300gb drives, I imagine that isn't suggested.. and may
hinder performance when using a system partition that big.
So my question would be in two parts I guess...
1. What is the suggested way to partition the system drive?
2. For the second 300gb drive, I'm going to purely use it for storage.
Should I partition this drive into multiple partitions as well, or go
with one big 300gb partition? Keeping in mind that no programs will
ever run from this drive.
Any suggestions on this are greatly appreciated.
Thanks in advance!
Kevin G.
Hello all,
Thanks in advance!
Kevin G.
