Best Wireless "N" Mini PCI
avspec
Just got a new TRENDnet TEW-633GR 300Mbps Wireless N Gigabit Router and I want to put a new "N" Mini PCI card into my Fujitsu tablet PC and wanted to find the best match for the new router.. or does it matter? It has to be Mini PCI and not the PCI-E.
Thanks,
-M
It doesn't matter. The only time it will is if the TRENDnet is advertising a proprietary technology that speeds things up and increases range. To take advantage of that you would have to stick with TRENDnet branded NIC's.
Other then that...any N card will work.
